NetApp Knowledge Base
Error when switching to Advanced View for CVO ONTAP system in BlueXP
11
Visibility:
Votes:
0
Category:
cloud-manager
Specialty:
bluexp
Last Updated:
Applies to
BlueXP
Issue
Navigating to the Advanced View for the CVO ONTAP instance shows the following:
Something went wrong. BlueXP is preparing the Connector. Please wait a few moments.
Service manager status showed as failed:
root@connector:/opt/application/netapp/service-manager-2# systemctl status netapp-service-manager. service
* netapp-service-manager. service - Netapp Service Manager
Loaded: loaded (/lib/systemd/system/netapp-service-manager.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2000-01-17 12:57:42 UTC; 1min 53s ago
Process: 84165 ExecStart=/opt/application/netapp/service-manager-2/sm2 (code=exited, status=1/FAILURE)
Main PID: 84165 (code=exited, status=1/FAILURE)
CPU: 1.183s
Jan 17 12:57:42 connector systemd[1] : netapp-service-manager. service: Scheduled restart job, restart count>
Jan 17 12:57:42 xxx-amc-dr-netapp-connector systemd[1]: Stopped Netapp Service Manager.
Jan 17 12:57:42 connector systemd[1]: netapp-service-manager. service: Consumed 1.183s CPU time.
Jan 17 12:57:42 connector systemd[1]: netapp-service-manager. service: Start request repeated too quickly.
Jan 17 12:57:42 connector systemd[1] : netapp-service-manager. service: Failed with result 'exit-code'.
Jan 17 12:57:42 connector systemd[1]: Failed to start Netapp Service Manager.
Checking the BlueXP logs showed the service manager was not updated to the latest version.
{"level":"error","message":"[-] Failed to update service manager binary: Error: read ECONNRESET","timestamp":"2000-00-09T07:19:01.835Z"}
New to NetApp?
