Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
NetApp H610S has NETWORK_FIRMWARE_VERSION mismatch alert after node downgrade or RMA replacement
409
Visibility:
Votes:
0
Category:
h-series
Specialty:
solidfire
Last Updated:
Applies to
  • NetApp Element software 10.4
  • NetApp H610S storage node
Issue
After downgrading (usually while adding a new node to a cluster or for an RMA replacement) H610S node generate alerts which states that the current NIC firmware is higher than expected and supported for this version of Element as below;
NETWORK_FIRMWARE_VERSION_ETH0 should be == 14.20.1010 (MT_2420110034) but is 14.22.1002 (MT_2420110034)
NETWORK_FIRMWARE_VERSION_ETH1 should be == 14.20.1010 (MT_2420110034) but is 14.22.1002 (MT_2420110034)
Note: Please see Additional Information for a full description of the alert.
New to NetApp?
Scan to view the article on your device
