NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
How to rebuild the NetApp HCI management node Docker swarm overlay network
418
Visibility:
Votes:
0
Category:
netapp-hci
Specialty:
solidfire
Last Updated:
Applies to
  • HCI Compute Boot OS
  • HCI Cluster Performance
  • HCI Deployment Engine/Monitoring Agent
This article guides you through manually rebuilding the Docker swarm network when there is an IP address space conflict with NetApp HCI.
In some circumstances, after a successful NetApp HCI deployment, you might not be able to update the management services. After you click the Update Services button in NetApp Hybrid Cloud Control, the update dialog hangs indefinitely. When this happens, the management services API Web interface is also unavailable (https://<mnodeIP>/mnode).
This is caused when the Docker swarm overlay network address space (10.255.0.0/16) overlaps with your network. In this scenario, you need to recreate the overlay network in a different address space.
New to NetApp?
Scan to view the article on your device
