NetApp Knowledge Base
How to enable multipathing with SolidFire volumes using OpenStack Nova
24
Visibility:
Votes:
0
Category:
openstack
Specialty:
solidfire
Last Updated:
Applies to
  • OpenStack multipathing settings with in Nova for Ubuntu systems running versions 16 and 18.
  • Applies to moving from non-multipathing to multipathing with in OpenStack Nova.
Best Practices on enabling multi-pathing with SolidFire volumes using OpenStack NOVA Version
Problem Signature:
The client VM hangs when attempting to mount a ElementOS/SolidFire volume with incorrect configuration.
This is a known issue with Ubuntu-16 and 18 and is fixed in version 20. The issue occurs because the IQN of the SolidFire volume becomes too long.
Current Bug: Multipathd hangs with long iscsi target names in Ubuntu 18.04
Nova database field connection_info has a dictionary which contains the field 'target_portal' (non-multipath). There are other fields as well in that dictionary.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • Was this article helpful?
