NetApp Knowledge Base
How to determine which VLAN IP's are in use and which nodes those IP's are assigned to in Element
129
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • Element Software
  • NetApp HCI
Element Software supports the creation of one or multiple virtual networks on the cluster which have their own, VLAN-specific set of IP's on the storage network.
With the exception of the VLAN-specific SVIP, the VLAN-specific IP addresses in use across the nodes does not appear in the Element Web UI; however, they can be determined through a combination of the ListVirtualNetworks and ListActiveNodes cluster API commands.
New to NetApp?
Scan to view the article on your device
