NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
How to add a compute node into a VDS-enabled HCI cluster when Easy Scale fails with an EVC error
464
Visibility:
Votes:
0
Category:
netapp-hci
Specialty:
hci
Last Updated:
Applies to
  • HCI 1.6
  • HCI 1.7
  • EVC enabled in ESX
  • CVE-2018-3646 vulnerabilities have been patched on nodes in the cluster
  • VDS in use on the ESX cluster
When attempting to add a net-new or replacement compute node into an HCI cluster, the Easy Scale function of the NetApp Deployment Engine (NDE) fails to add the node and generates the error below:
Error Statement: {'task_id': 'task:14', 'error': '(vim.fault.EVCAdmissionFailedCPUModelForMode) {\n dynamicType = <unset>,\n dynamicProperty = (vmodl.DynamicProperty) [],\n msg = "The host\'s CPU hardware does not support the cluster\'s current Enhanced vMotion Compatibility mode. The host CPU lacks features required by that mode."
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
