NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
How to RTFI a NetApp HCI node or Storage Node using a USB key
2,509
Visibility:
Votes:
2
Category:
netapp-hci
Specialty:
solidfire
Last Updated:
Applies to
  • HCI Compute Nodes
    • H410C
    • H610C
    • H615C
    • H300E/H500E/H700E (deprecated; now H410C)
  • HCI Flash Storage Node
    • H610S
  • SF Series Storage Nodes
    • SF3010/SF6010/SF9010 (legacy, EOA)
    • SF2405/SF4805/SF9605/SF19210/SF38410 (EOA)
  • FC Series Fibre Channel Nodes
    • FCN001 (EOA)
    • FC025 (EOA)
  • HCI Deployment Engine/Monitoring Agent
Use this procedure to RTFI an HCI node using a USB key.
Note: For compute nodes that already have ESXi installed, using this procedure with NetApp HCI 1.6+ Compute BootStrap OS ISO image will update the firmware and the Bootstrap OS on that compute node leaving ESXi and configuration data intact. The only way to reset an existing ESXi installation starting with NetApp HCI 1.6+ is to use the Factory Reset option from the Compute TUI.
For the HCI storage nodes, use the existing methods to copy the Element Software ISO image onto the USB key.
For the HCI compute nodes, it is recommended to use Linux ‘dd’ command to do a raw copy of the Compute BootStrap OS ISO image onto the USB key.
Note: Due to the larger size of the compute ISO image, it is possible that RTFI may show failures if the USB key is created using 3rd party USB creator applications.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
