Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
Easy Scale fails with EVC error when scaling a compute node into an HCI cluster using VSS
805
Visibility:
Votes:
0
Category:
netapp-hci
Specialty:
hci
Last Updated:
Applies to
  • HCI 1.6
  • HCI 1.7
  • EVC enabled in ESX
  • CVE-2018-3646 vulnerabilities have been patched on nodes in the cluster
  • VSS in use on the ESX cluster
Issue
When attempting to add a net-new or replacement compute node into an HCI cluster, the Easy Scale function of the NetApp Deployment Engine (NDE) fails to add the node and generates the error below:
Error Statement: {'task_id': 'task:14', 'error': '(vim.fault.EVCAdmissionFailedCPUModelForMode) {\n dynamicType = <unset>,\n dynamicProperty = (vmodl.DynamicProperty) [],\n msg = "The host\'s CPU hardware does not support the cluster\'s current Enhanced vMotion Compatibility mode. The host CPU lacks features required by that mode."
New to NetApp?
Scan to view the article on your device
