Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
Applying Storage Firmware Bundle fails due to "Maintenance mode process failed"
21
Visibility:
Votes:
0
Category:
netapp-hci
Specialty:
solidfire
Last Updated:
Applies to
  • NetApp Hybrid Cloud Control (HCC)
  • Management Services 2.19.48
  • NetApp Element software
Issue
  • Applying Storage Firmware Bundle via HCC fails with error:
An error has occurred during the upgrade for storage cluster <CLUSTER_NAME>. Contact your technical support engineer. You can resume the upgrade after the problem that caused the error is resolved.
Upgrading storage cluster <CLUSTER_NAME> to version: <PACKAGE-VERSION>.
Storage Cluster upgrade failed: Maintenance mode process failed. Contact your technical support engineer.
  • The log downloaded from Download Upgrade Logs reports errors:
Failed to update task monitor status: 404 Client Error: NOT FOUND for url:   http://mnode-svc-task-monitor/task-monitor/1/tasks/<TASK-ID>
Upgrade failure occurred. One of the nodes is in maintenance mode.
New to NetApp?
Scan to view the article on your device
