Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
How to use the micro-USB to USB console cable with a Windows host
7,584
Visibility:
Votes:
30
Category:
host-utilities
Specialty:
hw
Last Updated:
Applies to
  • Windows 7 host
  • Windows 10 host
  • NetApp controllers are equipped with an internal console micro USB serial port
  • Either a standard USB A to micro USB B can be used or NetApp cable with part number X-26009-00, X65420, or 112-00508
  • The embedded serial port in the controller provides the logic, the cable is more of an extension to the serial port
  • This procedure identifies how to connect a USB-equipped Windows host to the serial port on the NetApp controller
New to NetApp?
Scan to view the article on your device
