NetApp Knowledge Base
How to access and use the Interoperability Matrix Tool (IMT)
18,570
Visibility:
Votes:
19
Category:
not set
Specialty:
generalsupport
Last Updated:
The Interoperability Matrix Tool is the NetApp utility used to determine the officially supported configurations of NetApp and non-NetApp products across key components in the customer’s environment.
Note: IMT was designed to only represent supported configurations:
  • if a configuration appears in IMT, it is supported.
  • If a configuration does not appear in IMT, it May Not be supported.
If you have any questions or concerns regarding your configuration and whether its supported or not, follow How to proceed when configuration is not found in IMT?
  • Before filing a ticket, you may want to check the FAQ section to see if this topic has already been addressed
New to NetApp?
