NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
SolidFire Cluster down with MVIP and SVIP unresponsive
93
Visibility:
Votes:
0
Category:
solidfire-chassis
Specialty:
solidfire
Last Updated:
Applies to
NetApp SolidFire
Issue
  • After all nodes in the cluster were shut down and powered back up, the cluster will not come up.
  • Management Virtual IP (MVIP) and Storage Virtual IP (SVIP) unreachable.
  • Nodes are up
    • Web UI and TUI shows them as active participants in a cluster with correct IPs, cluster name, and active ports
    • Diagnostics such as ping between nodes, connectivity tests, ensemble check all fail due to xDBOperationTimeout
    • 1Gb, 10Gb, and IPMI IPs are reachable from other devices within the same network
  • Attempts to access a node management IP without the 442 port redirect to /createcluster/clusterstopped.htm
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
