Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Slice service crashes with signal SIGSEGV Segmentation fault
68
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
Element OS 12.5
Issue
Slice service crashes with signal SIGSEGV, Segmentation fault
  • Crash dump
GNU gdb (Gentoo 9.2 vanilla) 9.2
Reading symbols from /sf/bin/sfapp...
Reading symbols from /sf/bin/sfapp.debug...
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
--Type <RET> for more, q to quit, c to continue without paging--
Core was generated by `sfapp -service=slice -serviceid=ID# -vserviceid=ID# -tserviceid=ID# -noruninproces'.
Program terminated with signal SIGSEGV, Segmentation fault.
  • Kernel.log
2022-08-27T17:23:49.386992Z node_name kernel: [2700569.480857] libmicro httpd[162826]: segfault at 1d8 ip 00007f754788b8c0 sp 00007f5a626e7158 error 4 in libpthread-2.32.so[7f7547885000+10000]
2022-08-27T17:23:49.386999Z node_name kernel: [2700569.480864] Code: 06 8b 56 04 89 47 30 31 c0 85 d2 0f 95 c0 89 47 1c 31 c0 c3 66 0f 1f 44 00 00 31 c0 c3 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 00 <8b> 57 18 64 8b 04 25 d0 02 00 00 39 c2 0f 84 65 01 00 00 41 57 41
New to NetApp?
Scan to view the article on your device
