NetApp Knowledge Base
SRM/SRA TestFailover fails if the SolidFire volume replication type is Snapshots Only
110
Visibility:
Votes:
0
Category:
solidfire-storage-replication-adapter
Specialty:
solidfire
Last Updated:
Applies to
  • NetApp SolidFire StorageReplication Adapter (SRA)- 2.0.1
  • VMware SRM
  • Element OS - All Version
Issue
When running a failover test using VMware SRM and NetApp SolidFire SRA on a volume replication set as "Snapshots Only" you get the following message below.
Error - Failed to create snapshots of replica devices. Failed to create snapshot of replica device HCI-cluster:117296FE:24. SRA command 'testFailoverStart' failed for device 'HCI-cluster:117296FE:24'. No existing snapshot found SnapshotOnly replicated volumes require an existing snapshot to perform a failover or failover test
From SRA logs
2020-08-24 11:19:42.901 INFO  ReplicationService - Target volume [24] is replicating in SnapshotsOnly mode so locating the latest existing replicated snapshot on the volume
2020-08-24 11:19:42.901 ERROR ReplicationService - No existing replicated snapshot of volume [24] was found.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
