H610S - BMC can't be accessed after some maintenance on the node
Applies to
NetApp H610S
Issue
The BMC can't be accessed in below scenarios:
- After the node is performed power drain reboot as the following procedure
- After the node is performed upgrade
- After RTFI or iRTFI the node(Add node)
