NetApp Knowledge Base
Errors updating a Solidfire nodes network setting due to misconfigured fields in the unused 1G bond settings
122
Visibility:
Votes:
0
Category:
sf-series
Specialty:
solidfire
Last Updated:
Applies to
Element Software (all versions)
Issue
Network configuration mismatch errors are generated when updating an Element storage node's network settings via API or per-node UI (        https://<node_management_ip>:442):
Detected network configuration mismatch on Bond1G: { - "#default" : false, "bond-downdelay" : "0", "bond-fail_over_mac" : "None", "bond-miimon" : "100", @@ -8,7 +7,7 @@ "bond-slaves" : "eth2 eth3", "bond-updelay" : "200", "family" : "inet", - "method" : "none", + "method" : "static", "mtu" : 1500, - "status" : "UpAndRunning" + "status" : "Down" }”
ApiServerError(method_name="SetNetworkConfig", err_json=500 xAPIMethodFailed Malformed network configuration on Bond1G: empty address or netmask)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
