NetApp Knowledge Base
Error starting a collector for asset=mnode_hostname
87
Visibility:
Votes:
2
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • SolidFire Element Software
  • Management Node versions 12.3
Issue
  • This management node(mNode) is managing 2 storage clusters
  • After re-create ingress network in a new address space
  1. mNode stop forwarding the first storage cluster data to Active IQ
  2. mNode is stil able to forward the second storage cluster data to Active IQ
  • mnode_mnode-svc-aiq-collector log indicates below error message
mnode_mnode-svc-aiq-collector.1.w6cmf8p95e1nsdbnt0vuse1xx
May 02 2022 02:25:09.491 INFO Starting collector(s) for SF-xxxx
May 02 2022 02:25:09.491 INFO Starting collector for SF-xxxx storage_id=1054c4d2-xxxx-xxxx-xxxx-xxxxxxxxxxxx
May 02 2022 02:25:09.510 INFO Starting collector for SF-xxxx storage_id=577a07f5- xxxx-xxxx-xxxx-xxxxxxxxxxxx
May 02 2022 02:25:09.516 ERROR Error starting a collector for asset=SF-xxxx - continuing on to allow other collectors to start if present: ('Connection aborted.', error(104, 'Connection reset by peer'))
Traceback (most recent call last):
File "mnode-aiq-collector.py", line 46, in startup
File "mnode-aiq-collector.py", line 64, in _start_collector_process
File "mnode-aiq-collector.py", line 196, in _get_mnode_credential
File "site-packages/requests/sessions.py", line 555, in get
File "site-packages/requests_oauthlib/oauth2_session.py", line 360, in request
File "site-packages/requests/sessions.py", line 542, in request
File "site-packages/requests/sessions.py", line 655, in send
File "site-packages/requests/adapters.py", line 498, in send
ConnectionError: ('Connection aborted.', error(104, 'Connection reset by peer'))
New to NetApp?
