Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
'Detected network configuration mismatch on Bond1G/Bond10G' alert on SolidFire node
289
Visibility:
Votes:
0
Category:
element-software
Specialty:
solidfire
Last Updated:
Applies to
  • NetApp SolidFire
  • NetApp HCI Storage Node
Issue
  • The following networkConfig warning is detected from the Active IQ.
Example:
Detected network configuration mismatch on Bond1G:
{ - "#default" : false,
+ "#default" : true,
"address" : "xx.xx.xx.xx",
"auto" : true,
"bond-downdelay" : "0",
@@ -9,10 +9,18 @@
"bond-primary_reselect" : "Failure",
"bond-slaves" : "eth2 eth3",
"bond-updelay" : "200",
+ "dns-nameservers" : "xx.xx.xx.xx",
"family" : "inet",
+ "gateway" : "xx.xx.xx.xx",
"method" : "static",
"mtu" : "1500",
"netmask" : "xx.xx.xx.xx",
"network" : "xx.xx.xx.xx",
- "status" : "UpAndRunning"
+ "status" : "UpAndRunning",
+ "symmetricRouteRules" : [ + "ip route add xx.xx.xx.xx/23 dev Bond1G src xx.xx.xx.xx table Bond1G",
+ "ip route add default via xx.xx.xx.xx",
+ "ip route add default via xx.xx.xx.xx dev Bond1G src xx.xx.xx.xx table Bond1G",
+ "ip rule add from xx.xx.xx.xx table Bond1G" + ] }
  • The cluster is created and then all node's eth3 cables are removed before the above warning is detected.
New to NetApp?
Scan to view the article on your device
