NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
How to troubleshoot issues with auto-code sync/controller replacement
464
Visibility:
Votes:
1
Category:
ef-flash-array
Specialty:
esg
Last Updated:
Applies to
  • E-Series
  • Flash Array
  • E-Series Triage Template
1029707-1.png TECHNICAL TRIAGE TEMPLATE
Section 1: Usage
Use:
  • Refer this TTT during a new case creation on the NetApp Support site
  • It is used by TSEs/Partners when a customer calls support directly, to help frame the issue
  • Section 2 provides links to most common solutions and additional resources for the Product/Technology
  • Section 3 provides steps to gather the relevant data to open a case
Product/Technology: E-Series
Audience:
Customer/Partner/TSE unfamiliar with the Product/Technology
This template is intended to aid in recovering from an auto-code sync issue or a controller replacement issue.
Note: On XBB2 (7900) systems, removing a single controller disconnects one of the AC power supplies and causes the processor to overheat if one controller is pulled from the system for more than 15 minutes. Leave the failed controller in the system until ready for replacement.
Section 2: Solutions
  • E-Series documentation can be accessed here
  • SANtricity documentation cane be accessed here
Section 3: Troubleshooting
The common issues with controller replacement are:
  • auto-code sync
  • submodel ID mismatch
  • damaged hardware
Auto-code sync and submodel ID mismatch errors are displayed in the serial console output.
Symptomatically, the controller that fails to ACS or has a submodel ID mismatch is typically going to be marked offline automatically by the surviving controller, and report entries such as the following in the Recovery Guru:
Offline_Controller
Submodel_Mismatch
Failed_Controller
The seven segment LED display should display one of the following codes:
  • L0 - mismatched controller types
  • L7 - Submodel ID not set or mismatched
  • LH - Controller firmware mismatch
  • L5 - Auto Code-Synchronization failure
  • LU - Start of day reboot limit exceeded
  • OS - OL - (switching back and forth between OS and OL) - Operational State Offline
  • 88 - Controller Held in Reset
Note: There can be additional 7-segment LED display codes that occur, the list above is a list of common codes that might indicate an ACS issue.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
