NetApp Knowledge Base
Unable to rename Node Management LIFs automatically generated with UUID names
175
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
Issue
Following the controller upgrade procedure of upgrading by moving volumes, you prepare the original nodes and join the new nodes to the cluster. You move volumes to the new nodes, configure LIFs, and unjoin the original nodes from the cluster.
node management LIF was automatically created and unable to rename.
cluster::> network int rename -vserver <vserver-name> -lif <UUID>_mgmt1 -newname <newname_of_lif>
(network interface rename)
Error: command failed: Cant assign LIF to failover group Default because group does not exist
Example:
::> net int rename -vserver svm01 -lif 3d7453f8-2580-22cd-ef15-e167db892737_mgmt1 -newname node_mgmt1
New to NetApp?
Scan to view the article on your device
  • Was this article helpful?
