The inventory information of FRU PSUx is not readable
Applies to
- AFF A220
- FAS2554
Issue
- EMS error messages example:
Wed May 19 09:56:06 +0000 [node1: env_mgr: monitor.fru.info.unreadable:error]: The inventory information of FRU PSU1 is not readable.
Wed May 19 09:56:06 +0000 [node1: env_mgr: monitor.fru.info.unreadable:error]: The inventory information of FRU PSU2 is not readable.
Wed May 19 10:00:00 +0000 [node1: statd: monitor.fan.failed:alert]: Multiple fans has failed.
Wed May 19 10:44:46 +0000 [node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
Wed May 19 10:44:46 +0000 [node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
Wed May 19 10:44:46 +0000 [node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
Wed May 19 10:44:46 +0000 [node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.
Wed May 19 10:45:28 +0000 [node1: env_mgr: monitor.fan.warning:notice]: multiple fans have failed. Replace it to avoid overheating
Wed May 19 10:45:57 +0000 [node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
Or
Sun Feb 27 16:08:11 +0900 [node1: env_mgr: monitor.fru.info.unreadable:error]: The inventory information of FRU PSU3 is not readable.
Sun Feb 27 17:07:11 +0900 [node1: env_mgr: monitor.fru.info.readable:info]: The inventory information of FRU PSU3 is readable.
- Platform sensor error example:
PSU1 Fan 1 and PSU1 Fan 2 init-failed
PSU2 Fan 1 and PSU2 Fan 2 init-failed
sysconfig -a
output example:
Shelf 0: DS224-12 Firmware rev. IOM12E A: 0220 B: ----
- ONTAP OS boot error:
LOADER-B> boot_ontap
Loading X86_64/freebsd/image1/kernel:0x200000/1091691 0x30b000/10940288 0xf7a000/3783336 0x1315aa8/13717528
This platform is not supported in this release.
The system will now halt
BIOS Version: 11.9
Loading Device Drivers ...
Waiting for SP
IPMI:Read midplane FRU common header:timeout
SP failure. Resetting SP from primary FW. This can take a few minutes
