NetApp Knowledge Base
System is going to shutdown because NVMEM subsystem failed initialization or configuration check panic received after NDVIMM replacement
205
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • AFF A800
  • NVDIMM
  • ONTAP 9
Issue
After NVDIMM replacement, the system panics after a 30 minute timeout expires:
/etc/netapp_loadnvram: 1: not found
Loading NVDIMM1 firmware version 2.6.2.c (was 2.5.2.c)
Programming NVDIMM1 FW. This could take over 8 minutes. Please wait...
..................................................................................Tue May  4 15:53:54 2021 [nvdimm.fw.upgrade.succeed:NOTICE]:NVDIMM controller firmware in slot-23 was upgraded to 2.6.2.c.
.........[nvdimm.nvmem.initfail:FAULT]:NVDIMM startup failed due to FW upgrade timeout. To prevent NVMEM data loss, halt the system.
Set bootarg.init.battery_override can ignore this error and continue to boot.
PANIC  : System is going to shutdown because NVMEM subsystem failed initialization or configuration check.
Dumper is not yet registered. A coredump will not be available at this time.
System halting...
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
