System fails to boot with "SP failure. Resetting SP from primary FW" message
Applies to
- ONTAP 9
- AFF-A300
Issue
- Service Porcessor (SP) reports "
SP load is high
" error in the console log and a node goes down. - ONTAP is unable to boot from Loader with the following error after the node down.
Example:
LOADER-A> boot_ontap
Loading X86_64/freebsd・・・
Starting program at ・・・
NetApp Data ONTAP 9.3P4
This platform is not supported in this release.
The system will now halt
BIOS Version: 11.1
Portions Copyright (C) 2014-2017 NetApp, Inc. All Rights Reserved.
Initializing System Memory ...
Loading Device Drivers ...
Waiting for SP ...
SP failure. Resetting SP from primary FW. This can take a few minutes
- Even if the controller is replaced, the system gets the same error and cannot boot the system.
- The following message appears in the BMC
events all
log on the partner node.
Example:
Record 649: Sat Oct 15 13:05:38.834785 2016 [Agent.notice]: 720.089: 150 : Local Serial Exchange Error Internal MLER[4] asserted
Record 1003: Mon Oct 17 08:38:52.362718 2016 [Agent.notice]: 193.618: 151 : Local Invalid Serial Exchange Bus Internal MLER[5] asserted
Record 807: Thu Jan 01 00:00:36.931067 1970 [Agent.notice]: 000.267: 152 : Midplane I2C Local Buffers Not Ready Internal MLER[6] de-asserted
Record 797: Mon Oct 17 08:52:11.001689 2016 [Agent.notice]: 919.800: 148 : Midplane Local Grant Timeout Internal MLER[2] asserted
