NetApp Knowledgebase
Permanent errors on all HA mailbox disks PANIC upgrading to 9.7P10
87
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
AFF A200
Issue
  • PANIC upgrading ONTAP to 9.7P10 from 9.5P6
Panic_Message: Permanent errors on all HA mailbox disks (while marshalling header) in SK process fmmbx_instanceWorker on release 9.7P10 (C)
  • Just one node reports:
node_name ERROR monitor.temp.unreadable: The controller temperature (Midplane 3 Temp) is not readable.
node_name ERROR monitor.temp.unreadable: The controller temperature (Midplane 4 Temp) is not readable.
node_name ERROR monitor.temp.unreadable: The controller temperature (Module A Expander Temp) is not readable.
node_name ERROR scsi.cmd.adapterHardwareErrorEMSOnly: Enclosure services device 0b.00.99: Adapter detected hardware error: HA status 0x6: cdb 0x1c.
  • Both Power Supplies (PSUs) work fine but:
monitor.globalStatus.critical: Chassis temperature is too high..
monitor.globalStatus.critical: Power Supply Status Critical: PSU2, PSU1.
monitor.globalStatus.critical: Multiple fans has failed. Chassis temperature is too high..
monitor.globalStatus.critical: Power Supply Status Critical: PSU2, PSU1. Chassis temperature is too high..
  • PLATFORM-SENSOR output:
PSU2 FRU  fru     fault normal PSU_OFF
PSU1 FRU  fru     fault normal PSU_OFF
PSU2 Bad discrete fault normal TRUE
PSU1 Bad discrete fault normal TRUE
PSU2 discrete     fault normal BAD
PSU1 discrete     fault normal BAD
PSU2 ON discrete  fault normal OFF
PSU1 ON discrete  fault
  • The issue remains with the Service Processor firmware and internal switch updated to the latest version.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
