ONTAP upgrade failure due to "post-apps" phase on task "OpenSSH 8.7 Upgrade/Revert Task"
Applies to
- ONTAP 9
- ONTAP upgrade
Issue
A post-update validation fails with the error:
Status Message: The upgrade failed in the "post-apps" phase on task "OpenSSH 8.7 Upgrade/Revert Task". Contact support personnel for the upgrade repair procedure
::> cluster image show-update-progress Estimated Elapsed Update Phase Status Duration Duration -------------------- ----------------- --------------- --------------- Pre-update checks completed 00:10:00 00:01:13 ONTAP updates paused-on-error 05:00:00 04:34:07 Details: Node name Status Status Description -------------------- --------------- -------------------------------------- Node_name waiting Node_name failed Error: Upgrade of node <node_name> failed to complete. Action: Use the (privilege: advanced)command "system node upgrade-revert show -node <nodename>" to check the upgrade status.
::> system node upgrade-revert show -node <node_name> (system node upgrade-revert show) Node: Node_name Status: failed Status Message: The upgrade failed in the "post-apps" phase on task "OpenSSH 8.7 Upgrade/Revert Task". Contact support personnel for the upgrade repair procedure.
::*> upgrade-revert show-task-status -node *
Node Vers Phase ID Proc Status Description
Node_name 1800 post-apps 1818 mgwd failed OpenSSH 8.7 Upgrade/Revert Task
