ONTAP upgrade failed due to corrupted boot device
Applies to
- FAS25xx
- Ontap 9
Issue
When attempting an upgrade, the installation fails with error:
Error: Install Failed. ERROR: Insufficient space available on device. ,
Action: Use the "cluster show" command to verify that all nodes in the cluster are healthy. Use the "cluster image package show-repository" command to verify that the downloaded image has the correct version. If all nodes are healthy and the image has the correct version, wait a few minutes, and then use the "cluster image resume-update" command to resume
the update.
