NetApp Knowledge Base
ONTAP reports multiple sensor errors on AFF A700 system
205
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9.3P6
  • Service Processor(SP) 4.3
Issue
ONTAP reports multiple sensor errors on AFF A700 system and recovers automatically.
Example:
[?] Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Inflow Temp is not readable
[?] Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Outflow Temp is not readable
[?] Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS ASIC DieTemp is not readable
[?] Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P3.3V is not readable
[?] Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.8V is not readable
[?] Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.0V is not readable
[?] Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P0.9V is not readable
[?] Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS 5V Standby is not readable
[?] Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P12V HS is not readable
[?] Thu Apr 30 00:27:59 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Hot Swap Cur is not readable
[?] Thu Apr 30 00:28:00 UTC [node: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high.
[?] Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
[?] Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.ioCard.ok:notice]: IO card on slot 9 is OK
[?] Thu Apr 30 00:29:00 UTC [node: monitor: monitor.globalStatus.ok:notice]: The system's global status is normal.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
