NetApp Knowledge Base
ONTAP reports multiple sensor errors on AFF A700 or FAS9000 system
713
Visibility:
Votes:
1
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF A700
  • FAS9000
Issue
ONTAP reports multiple sensor errors on AFF A700 system and recovers automatically.
Example:
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Inflow Temp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Outflow Temp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS ASIC DieTemp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P3.3V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.8V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.0V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P0.9V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS 5V Standby is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P12V HS is not readable
Thu Apr 30 00:27:59 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Hot Swap Cur is not readable
Thu Apr 30 00:28:00 UTC [node: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high.
Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.ioCard.ok:notice]: IO card on slot 9 is OK
Thu Apr 30 00:29:00 UTC [node: monitor: monitor.globalStatus.ok:notice]: The system's global status is normal.
New to NetApp?
Scan to view the article on your device
