We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
Node down with CHASSIS FAN FRU FAILED: SysFan3 F2 Alert
80
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF A300
Issue
  • Controller shuts down with multiple fan failure. Example:
env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F1 (1260 RPM)
env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F2 (1260 RPM)
env_mgr: monitor.chassisFanFail.xMinShutdown:EMERGENCY]: Multiple Chassis Fan failure: System will shut down in 2 minutes.
monitor: monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed: Sysfan3 F1, Sysfan3 F2.
statd: monitor.fan.failed:alert]: Multiple fans has failed: Sysfan3 F1, Sysfan3 F2.
statd: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
  • sysconfig -M output for that Fan:
Fri Jun 18 2021, 23:48:28 MSK !FAN3!021819020448!441-00025!A1!
Sat Jun 19 2021, 01:04:18 MSK !FAN3: Error reading FRU EEPROM
Sat Jun 19 2021, 07:05:27 MSK !FAN3!021819020448!441-00025!A1!
  • Issue remains after FAN replacement:
env_mgr: monitor.chassisFan.removed:alert]: Chassis fan SysFan3 is removed
env_mgr: monitor.chassisFan.ok:notice]: Chassis fan Sysfan3 Present is ok.
env_mgr: monitor.chassisFan.ok:notice]: Chassis fan Sysfan3 F1 is ok.
env_mgr: monitor.chassisFan.ok:notice]: Chassis fan Sysfan3 F2 is ok.
env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F1 (failed)
env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F2 (failed)
shutdown_thread0: ha.localNodeShutDown:notice]: Shutdown of the local node has been initiated with inhibit_takeover set to FALSE.
cf_main: cf.fsm.takeoverOfPartnerDisabled:error]: Failover monitor: takeover of cluster2-01 disabled (local halt in progress).
shutdown_thread0: kern.shutdown:notice]: System shut down because : "Environmental Shutdown".
Wed Jun 23 20:46:54 MSK [cluster2-04: mgwd: callhome.hm.alert.critical:alert]: Call home for Health Monitor process cphm: CriticalFanFruFaultAlert[021604000131].
Thu Jun 24 11:00:00 MSK [noed_name: statd: monitor.fan.failed:alert]: Multiple fans has failed: Sysfan3 F1, Sysfan3 F2.
Thu Jun 24 11:18:36 MSK [noed_name: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F1 (failed)
Thu Jun 24 11:18:37 MSK [noed_name: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F2 (failed)
Thu Jun 24 11:19:06 MSK [noed_name: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan3 F1
Thu Jun 24 11:19:06 MSK [noed_name: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: SysFan3 F2
Thu Jun 24 11:00:00 MSK [cluster2-01: statd: monitor.fan.failed:alert]: Multiple fans has failed: Sysfan3 F1, Sysfan3 F2.
Thu Jun 24 11:53:52 MSK [cluster2-01: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F1 (failed)
Thu Jun 24 11:53:52 MSK [cluster2-01: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: SysFan3 F2 (failed)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
