NetApp Knowledge Base
LUN not visible in a "lun show" command output
735
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
Applies to
  • ONTAP 9.4P6 and above
  • SAN
Issue
  • LUN not visible in lun show, however, it is visible on a full path.
  • LUN is also not visible in Autosupport.
  • debug smdb table d_vdisk_lun show shows LUN type correctly, however, vdom dump -metafile vtoc shows namespace and flag is not 0:
Example:
::*> debug smdb table d_vdisk_lun show -node NETAPP -dsid 5846 -type-filter all -fields type
node            dsid snapshot qtree lun                    type
NETAPP          5846 ""       ""    test_lun.lun           lun
::*> node run -node * -command vdom dump -metafile vtoc -d 5846 -h
4 entries were acted on.
Node: NETAPP
VTOC Header Contents
Magic Number: 1668248694
Major Version:  3
Minor Version:  2
Volume Flags: 0
Vdisk Count: 1
Sync op ctx:        0
Sync op gsid:      0
Namespace Name: test_lun.lun
Base fileid: 97
Record Contents:
      Base generation: 1200408254
      Clone parent fileid: 0
      Clone parent generation: 0
      Clone snapid: 0
      Flags: 2
vdom dump vtoc: found 1 records in 1 msecs
New to NetApp?
