NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Just one node reports increased temperature and the failure of both power supplies
76
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
AFF A250
Issue
  • Just one AFF A250 node reports high chassis temperature and two power supplies failures. Example:
::>event log show -event monitor*,chassis*
Severity  Event
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 1 is degraded: PSU1 In Fault is Unreadable
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 1 is degraded: PSU1 Fan is Unreadable
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 1 is degraded: PSU1 FB Hot is Unreadable
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 1 is degraded: PSU1 Hot is Unreadable
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 1 is degraded: PSU1 Inlet is Unreadable
ERROR     callhome.chassis.hitemp: Call home for CHASSIS OVER TEMPERATURE
EMERGENCY monitor.globalStatus.critical: Power Supply Status Critical: PSU2, PSU1. Chassis temperature is too high..
ERROR     monitor.temp.unreadable: The controller temperature (PSU2 FB Hot) is not readable.
ERROR     monitor.temp.unreadable: The controller temperature (PSU2 Hot) is not readable.
ERROR     monitor.temp.unreadable: The controller temperature (PSU2 Inlet) is not readable.
ERROR     monitor.temp.unreadable: The controller temperature (PSU1 FB Hot) is not readable.
ERROR     monitor.temp.unreadable: The controller temperature (PSU1 Hot) is not readable.
ERROR     monitor.temp.unreadable: The controller temperature (PSU1 Inlet) is not readable.
ERROR     callhome.chassis.ps.degraded: Call home for CHASSIS POWER SUPPLY DEGRADED: PS 1
ERROR     callhome.chassis.power: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU2, PSU1.
ALERT     monitor.chassisPower.degraded: Chassis power is degraded: Power Supply Status Critical: PSU2,PSU1.
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 2 is degraded: PSU2 Hot is Unreadable
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 2 is degraded: PSU2 Inlet is Unreadable
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 1 is degraded: PSU1 Out Fault is Unreadable
NOTICE    monitor.chassisPowerSupply.degraded: Chassis power supply 1 is degraded: PSU1 Warning is Unreadable
  • All sensors are ok in the partner node:
::> system controller environment show
Node               FRU Name                       State
netappv17-01       PSU2                           GOOD
netappv17-01       PSU1                           GOOD
netappv17-02       PSU2                           unknown
netappv17-02       PSU1                           unknown
  • One embedded NSM8E module reports:
[dsa_worker3: ses.status.enclWarn:error]: NS224NSM8E (S/N SHJHU0123456789) shelf 0 on channel 0s disk enclosure warning for Enclosure 1: VPD EEPROMs mismatch or unreadable. This element is on the unknown location.
[dsa_worker3: ses.status.ModuleWarn:alert]: NS224NSM8E (S/N SHJHU0123456789) shelf 0 on channel 0s PCI switch warning for PCI Switch 2: non-critical status; Backplane VPD SEEROM corrupt or unreadable. This element is on the rear of the shelf at the bottom, on shelf module (B).
  • storage show fault output:
Enclosure Status: non-critical
Channel: 0s
Shelf: 0
Shelf Type: NS224NSM8E
Module Type: NSM8E
Enclosure:
Element Status Status Bytes Status Descriptions
1: NONCRITICAL 03,00,00,00
PSM:
1 [NSM8E A] : NONCRITICAL 03,0C,00,00 MIDPLANE VPD FAULT, MASTER
2 [NSM8E B] : NONCRITICAL 03,04,00,00 MIDPLANE VPD FAULT
  • Issue remains after PSUs and node re-seat.
  • Issue remains with a known working PSU.
  • Issue follows one chassis slot, when swapping controllers between them.
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
