NetApp Knowledge Base
Is there a command I can run to determine if there is any Indirect cluster traffic?
290
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
perf
Last Updated:
Applies to
ONTAP 9
Answer
  • Run the following command on the cluster
cluster::> qos statistics volume latency show
Workload            ID         Latency         Network       Cluster       Data       Disk        QoS      NVRAM
-total-              -        110.35ms        110.02ms        1.65ms        0ms        0ms        0ms        0ms
-total-              -        38.830ms        167.22ms        0ms           0ms        0ms        0ms        0ms
-total-              -        117.76ms        117.56ms        0ms           0ms        0ms        0ms        0ms
Refer to the "Cluster" column and if it has a value > 0, then there is traffic on the cluster network.
Additional Information
