How to configure and Connect SUSE Enterprise Linux to ONTAP NVMe/FC namespaces
Applies to
All Flash FAS
This knowledgebase article details the host integration steps for enabling NVMe/FC support using SLES12 SP3 as an initiator.
At the time of writing this KB, the versions listed in this article are the current supported versions. However, because NVMe/FC is under rapid development, versions can change and the number of items qualified will continue to expand rapidly. For this reason, and because it is always a best practice, always check the IMT and adjust versions and hardware specifications to those listed in the IMT.
The IMT can be found here:
https://mysupport.netapp.com/matrix/#welcome
