Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Flash Cache NVMe Offline - AutoSupport Message
683
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • callhome.nvme.offline:alert
Event Summary
This message occurs when a directly attached NVMe module goes offline. When a module goes offline, it has either had a critical failure or is no longer reliable. In either case, the card is no longer functioning properly and was taken offline.
Validate
Call home event
HA Group Notification from Node Name (Flash Cache NVMe Offline) ALERT
EMS Log
event log show -severity * -message-name callhome*
Sat Mar 12 13:12:12 +0100 [Node Name: gemini-notif-thread: callhome.nvme.exhausted:alert]: Callhome for Flash Cache NVMe Offline.
Command Line
system node run -node <node name> -command sysconfig
	slot 1: Flash Cache NVMe
		Serial Number:      XXXXXXXX
		Part Number:        119-00329
		Hardware Revision:  A0
		Firmware Version:   NA03
		Firmware File:      X3311_S00005000NVM
		Model Name:         X3311A
		Capacity:           1024 GB
		State:              failed
Resolution
  • Please contact NetApp Technical Support and reference this article for further assistance. The solution might require a part replacement.
Additional Information
Scan to view the article on your device
