40G/100G Ethernet Controller CX5 card missing and PANIC
Applies to
- FAS8300/FAS8700/A400
- X1148A: 40G/100G Ethernet Controller CX5
Issue
- Card missing in
sysconfig -a
output
- Card "not supported" in
sysconfig -ac
sysconfig: Card in slot 1 (1-15B3-1017-0) is not supported.
sysconfig: slot 3 OK: X1151A: 2p 100G Naples-100 Smart IO
sysconfig: slot 4 OK: X1148A: 40G/100G Ethernet Controller CX5
sysconfig: slot 5 OK: X1148A: 40G/100G Ethernet Controller CX5
- A PANIC can be triggered by that card:
Panic String: Uncorrectable Machine Check Error at CPU1. SKL_IIO Error: STATUS<0xbb80000000000e0b>(VALID,UC,EN,MISCV,PCC,S,AR,CORR_ERR_STATUS(0),CORR_ERR_CNT(0),MSCOD(0),MCACOD(0xe0b))MISC<0x0000000017000000>(UCR_BUS_LOG(23),UCR_DEVICE_LOG(0),UCR_FUNCTION_LOG(0),UCR_SEGMENT_LOG(0))IIO Machine Check from device(s):RPT(23,0,0):ErrSrcID(CorrSrc(0),UCorrSrc(0x1a00)), Mellanox CX5 Ethernet in slot 1 on Controller, Mellanox CX5 Ethernet in slot 1 on Controller. in process idle: cpu1 on release 9.7P6 (C)
