Errors applying RCF file to Cisco Nexus 3132V-Q Cluster Switch
Applies to
- Cisco Nexus 3132V-Q cluster network switch
- NX-OS 9.3.7
- RCF1.6 (Cluster-HA-Breakout)
Issue
Errors seen when applying RCF to the switch
`switch(config)# interface port-channel1`
`switch(config-if)# switchport mode trunk`
`switch(config-if)# spanning-tree port type network`
Warning: Bridge Assurance MUST be enabled at the remotely connected interface
`switch(config-if)# mtu 9216`
`switch(config-if)# no shutdown`
`switch(config-if)# class-map type qos match-all HA`
`switch(config-cmap-qos)# match cos 5 `
`switch(config-cmap-qos)# policy-map type qos HA `
`switch(config-pmap-qos)# class HA`
`switch(config-pmap-c-qos)# set qos-group 5`
`switch(config-pmap-c-qos)# class class-default`
`switch(config-pmap-c-qos)# set qos-group 0`
`switch(config-pmap-c-qos)# policy-map type queuing HA_EGRESS`
Invalid class referenced
% Invalid command at '^' marker.
`switch(config)# class type queuing c-out-8q-q6`
ERROR: Cannot modify system defined queuing class-maps
