Does AIQ Unified Manager keep failed disks in a failed disk registry?
Applies to
- ONTAP 9
- AFF-A800
- AIQ Unified Manager
Answer
No, AIQ Unified Manager receives API calls from ONTAP every 15 minutes. Once there is a disk failure on an AFF A800 ONTAP will disable the NVMe drive PCI port. ONTAP does this by design to prevent false panics from the failed disk.
Additional Information
- EMS Alert: [NODE:config_thread: callhome.fdsk.fault:error]: Call home for FILESYSTEM DISK FAILEDShelf 0, Bay 37, Model [XmodelnumberX], S/N [XserialnumberX]
- If you have experienced a disabled link of a NVMe drive on AFF A800 you may need to replace the disk.
- An enhancement for disk registry in AIQ Unified Manger is currently under review by Engineering. Check with NetApp Support for updates.
