NetApp Knowledge Base
Command 'power show' fails with ' Error: The Service Processor on node "Node-02" is not reachable'
1,777
Visibility:
Votes:
2
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF Systems
  • FAS Systems
  • ONTAP 9
Issue
  • Error while running the command: system node power show
Cluster::> power show
(system node power show)
Node Status
node1 on
Error: The Service Processor on node "node2" is not reachable. Check the
network configuration, verify that the node is running, verify that the
SP is online, verify that api-service is enabled on the SP, and try the
command again.
node2 -
2 entries were displayed.
  • The command is failing for all the node except the node hosting cluster-mgmt LIF.
  • In above output, node1 is hosting the cluster-mgmt LIF and the command is working for node1.
New to NetApp?
  • Was this article helpful?
