NetApp Knowledge Base
Can I resolve queue depth issue by moving FC links to additional HBA?
195
Visibility:
Votes:
0
Category:
aff-series
Specialty:
san
Last Updated:
Applies to
  • ONTAP
  • Fibre Channel
Answer
FC queue depth is per port not per Host Bus Adapter (HBA) so this aproach would not resolve the underlying port issue of SCSI queue exaustion.
Example:
Each HBA port could have a queue depth availble of 1945 ( 2048 -5 % for critical SCSI commands ) moving FC link to another HBA port would not change this.
Additional Information
NOTE: If receiving an error combined with a performance impact Performance issue with STIO TPD cmd alloc threshold reached handle
Please contact NetApp Technical Support or log into the NetApp Support Site to create a case. Reference this article for further assistance.
Alternatively :
  • Consider tune the environment and Hosts Calculate queue depth overview.
  • Consider add additional target ports and FC links
    • Example: from 2 target ports  per node go to 4 this may alleviate the queue depth pressure on each port.
  • Consider moving the environment to a HBA card with increased queue depth support for example 4096 ( - 5 % for critical SCSI commands).
To Check queue depth per port:
network fcp adapter show -fields queue-depth
