NetApp Knowledge Base
"CHASSIS POWER SUPPLY NEED TO BE REPLACED" error coming after PSU replacement
95
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF A320
  • AFF A700s
  • AFF A800
  • Process Controller Module (PCM)
Issue
  • Even after replacing the faulty PSU, both the nodes in HA will report the errors on replaced PSU
  • You will see the below Autosupport alert on a daily basis
 HA Group Notification (CHASSIS POWER SUPPLY NEED TO BE REPLACED: PS 2) ERROR
  • The below EMS alerts will be seen on an hourly basis on both the nodes in HA pair
Sat Aug 21 00:27:05 +0530 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Power Out is Critical Low (0 W)
Sat Aug 21 00:27:05 +0530 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Curr Out is Critical Low (0 mA)
Sat Aug 21 00:27:05 +0530 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Volt Out is Critical High (12598 mV)
Sat Aug 21 00:27:05 +0530 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Power In is Critical Low (0 W)
  • The "platform sensors" will be showing MULTIFAULT on the respective PSU
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
