NetApp Knowledge Base
NETWORK INTERFACE CARD FATAL ERROR - AutoSupport Message
332
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9.1
  • Data ONTAP 8 7-mode
  • callhome.netif.fatal
Event Summary
This message occurs when Network Interface Card encountered a fatal error.
Validate
AutoSupport Message
HA Group Notification from Node Name (NETWORK INTERFACE CARD FATAL ERROR) WARNING
EMS Log
event log show -severity * -message-name callhome*
[Node Name: TOE-2x10G-SFP/c0a: callhome.netif.fatal.error:error]: Call home for NETWORK INTERFACE CARD FATAL ERROR.
Command Line
 system node run -node <node name> -command sysconfig
    slot 0: Dual 10G Ethernet Controller T320E-SFP/KR
        Device Type:        CT-FE-3
        Version Number:        T3-SRAM1.1.0-BR1016-02-01-FW7.7.209-DR04
        Serial Number:        jb04050693
        c0a MAC Address:    00:a0:98:1d:6a:a8 (Encountered Fatal Error: 6)
        c0b MAC Address:    00:a0:98:1d:6a:a9 (Encountered Fatal Error: 6)
Resolution
  • Confirm that the adapter is enabled.
  • Check the health of the adapter cables.
  • If issue persists, please contact NetApp Technical Support and reference this article for further assistance. The solution might require a part replacement
Additional Information
N/A
New to NetApp?
