ASA has a larger Aggregate size for ONTAP 9.8 and later
Applies to
- All SAN Array (ASA)
- ONTAP 9.8
Issue
Two aggregates have the same disk type, the same number of RAID group, RAID group type, and the same number of disks in each RAID group, but with different aggregate size.
Example:
- Cluster1: ONTAP 9.8P10; Cluster2: ONTAP 9.7P17
- Aggr1 and aggr2 each has 42 disks (38 excluding parity) with usable size 33,629,468 MB (38 disks *884986 MB/disk), but has different aggregate size.
cluster1::> node run -node cluster1_nodeA -command sysconfig -r
Aggregate aggr1 (online, raid_dp) (block checksums)
Plex /aggr1/plex0 (online, normal, active, pool0)
RAID group /aggr1/plex0/rg0 (normal, block checksums)
RAID Disk Device HA SHELF BAY CHAN Pool Type RPM Used (MB/blks) Phys (MB/blks)
dparity e3b.00.3.0P1 e3b 0 0 0 SSD-NVM N/A 884986/226556480 884994/226558528
parity e3b.01.3.0P1 e3b 1 0 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3a.00.0.6P1 e3a 0 6 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3b.01.3.6P1 e3b 1 6 0 SSD-NVM N/A 884986/226556480 884994/226558528
RAID group /aggr1/plex0/rg1 (normal, block checksums)
dparity e3a.00.0.12P1 e3a 0 12 0 SSD-NVM N/A 884986/226556480 884994/226558528
parity e3b.01.1.12P1 e3b 1 12 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3a.00.0.18P1 e3a 0 18 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3b.01.3.16P1 e3b 1 16 0 SSD-NVM N/A 884986/226556480 884994/226558528
cluster2::*> node run -node cluster2_nodeA -command sysconfig -r
Aggregate aggr2 (online, raid_dp) (block checksums)
Plex /aggr2/plex0 (online, normal, active, pool0)
RAID group /aggr2/plex0/rg0 (normal, block checksums)
dparity e3b.00.1.8P2 e3b 0 8 0 SSD-NVM N/A 884986/226556480 884994/226558528
parity e3b.01.3.7P2 e3b 1 7 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3b.00.1.1P2 e3b 0 1 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3b.01.1.1P2 e3b 1 1 0 SSD-NVM N/A 884986/226556480 884994/226558528
RAID group /aggr2/plex0/rg1 (normal, block checksums)
dparity e3a.00.0.20P2 e3a 0 20 0 SSD-NVM N/A 884986/226556480 884994/226558528
parity e3b.01.1.19P2 e3b 1 19 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3b.00.3.13P2 e3b 0 13 0 SSD-NVM N/A 884986/226556480 884994/226558528
data e3b.01.1.13P2 e3b 1 13 0 SSD-NVM N/A 884986/226556480 884994/226558528
- Aggr1 have 28.86TB total size while aggr2 have 30.47TB
cluster1::> aggr show -fields diskcount,raidgroups,raidtype,size
aggregate diskcount raidgroups raidtype size
aggr1 42 "/aggr3/plex0/rg0 (block)","/aggr1/plex0/rg1 (block)"
raid_dp 28.86TB
cluster2::*> aggr show -fields diskcount,raidgroups,raidtype,size
aggr2 42 "/aggr2/plex0/rg0 (block)","/aggr2/plex0/rg1 (block)"
raid_dp 30.47TB
- The
storage aggregate show
command displays different wafl reserve percent on aggr1 and aggr2.
cluster1::> aggr show -fields wafl-reserve-percent
aggregate wafl-reserve-percent
aggr1 10%
cluster2::> aggr show -fields wafl-reserve-percent
aggr2 5%
- Calculate the aggregate size.
Aggr1: 33,629,468 MB * 0.90 (10% for wafl reserve)=30,266,521.2 MB=28.86 TB
Aggr2: 33,629,468 MB * 0.95 (5% for wafl reserve)=31,947,994.6 MB=30.47 TB
