AFF A800 fails to boot with MEMORY WARNING major code 0xED
Applies to
- AFF A800
- BIOS 13.6 - 13.13
- "Uncertain failure" memory warning
Issue
- Node fails to boot with the following console output:
Running full memory initialization.
MEMORY WARNING: Uncertain failure Major Code 0xED Minor Code 0x09
ERROR: [55] Memory not installed
ERROR: DXE IPL not found
- Specific DIMM slot information is not included in the error messages
- This can occur with any node reboot. If performing an ONTAP upgrade, this issue can cause the upgrade to fail or pause
