NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
AFF A400 FAS8700 and FAS8300 reboot with CHASSIS OVER TEMPERATURE SHUTDOWN EMERGENCY due to low memory
489
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • AFF A400
  • FAS8700 and FAS8300
  • BMC FW 13.4 and earlier
Issue
  • The node reboots after a shutdown.
  • Multiple sensors value shows na:
PVCCIN_CPU0 | na | Volts | na | na | 0.010 | 0.020 | 2.460 | 2.470 | na
PVCCIN_CPU1 | na | Volts | na | na | 0.010 | 0.020 | 2.460 | 2.470 | na
PVDDQ_ABC | na | Volts | na | na | 0.014 | 0.021 | 1.711 | 1.732 | na
PVDDQ_DEF | na | Volts | na | na | 0.014 | 0.021 | 1.711 | 1.732 | na
PVDDQ_GHI | na | Volts | na | na | 0.014 | 0.021 | 1.711 | 1.732 | na
PVDDQ_KLM | na | Volts | na | na | 0.014 | 0.021 | 1.711 | 1.732 | na
P1V05_PCH | na | Volts | na | na | 0.940 | 0.992 | 1.100 | 1.147 | na
CX5_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 80.000 | 85.000 | na
CX5_Temp2 | na | degrees C | na | na | 0.000 | 5.000 | 80.000 | 85.000 | na
RiserL_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserL_Temp2 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserM_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserM_Temp2 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserM_Temp3 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserM_Temp4 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserR_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserR_Temp2 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserR_Temp3 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
RiserR_Temp4 | na | degrees C | na | na | 0.000 | 5.000 | 60.000 | 70.000 | na
CPU0_Temp | na | degrees C | na | na | na | na | 90.000 | 100.000 | na
CPU1_Temp | na | degrees C | na | na | na | na | 90.000 | 100.000 | na
Mezz_Temp1 | na | degrees C | na | na | 0.000 | 5.000 | 80.000 | 85.000 | na
Mezz_Temp2 | na | degrees C | na | na | 0.000 | 5.000 | 54.000 | 57.000 | na
  • Multiple temperature sensors shows status "nc" in sel elist:
02/17/2022 | 16:57:53 | Temperature LED2_Temp | Lower Non-critical going low | Reading 4 < Threshold 3 degrees C
02/17/2022 | 16:58:00 | Temperature LED1_Temp | Lower Non-critical going low | Reading 4 < Threshold 3 degrees C
02/17/2022 | 17:48:22 | Temperature MP_Temp3 | Lower Non-critical going low | Reading 5 < Threshold 5 degrees C
02/17/2022 | 17:49:40 | Temperature System_Inlet | Lower Non-critical going low | Reading 5 < Threshold 5 degrees C
02/17/2022 | 17:49:55 | Temperature MP_Temp1 | Lower Non-critical going low | Reading 5 < Threshold 5 degrees C
02/17/2022 | 17:50:09 | Temperature MP_Temp1 | Lower Non-critical going low | Reading 6 < Threshold 5 degrees C
02/17/2022 | 17:50:15 | Temperature MP_Temp1 | Lower Non-critical going low | Reading 5 < Threshold 5 degrees C
02/17/2022 | 17:50:40 | Temperature MP_Temp1 | Lower Non-critical going low | Reading 6 < Threshold 5 degrees C
  • Example of what is shown before the reboot:
Nov 11, 2020 07:00:41  0100 HA Group Notification (CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1, PSU2.) ERROR
Nov 11, 2020 07:34:52  0100 HA Group Notification (CHASSIS OVER TEMPERATURE SHUTDOWN) EMERGENCY
Nov 11, 2020 10:16:20  0100 HA Group Notification (BATTERY ('Bat Temp' unreadable)) EMERGENCY
Nov 11, 2020 10:16:55  0100 HA Group Notification (BATTERY ('Bat Volt' unreadable)) EMERGENCY
Nov 11, 2020 10:17:07  0100 HA Group Notification (BATTERY ('Bat Curr' unreadable)) EMERGENCY
Nov 11, 2020 10:17:18  0100 HA Group Notification (BATTERY ('Bat Full Cap' unreadable)) EMERGENCY
Nov 11, 2020 10:17:40  0100 HA Group Notification (CHASSIS FAN FRU FAILED: Fan1_1) ERROR
Nov 11, 2020 10:17:54  0100 HA Group Notification (CHASSIS FAN FRU FAILED: Fan2_1) ERROR
Nov 11, 2020 10:18:08  0100 HA Group Notification (CHASSIS FAN FRU FAILED: Fan2_2) ERROR
Nov 11, 2020 10:18:19  0100 HA Group Notification (CHASSIS FAN FRU FAILED: Fan3_1) ERROR
Nov 11, 2020 10:18:30  0100 HA Group Notification (CHASSIS FAN FRU FAILED: Fan3_2) ERROR
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
