AFF A250 fails to boot with Waiting for reservations to clear
Applies to
- AFF A250
- AFF C250
Issue
- One node fails to boot with repeated:
Press Esc-T or Ctrl-D to exit
- HA interconnect links are up in the partner node, but IC RDMA is down:
::> set advanced
::*> system ha interconnect status show
Node: node_name
Link 0 Status: up
Link 1 Status: up
Is Link 0 Active: true
Is Link 1 Active: true
IC RDMA Connection: down
- The cluster ports are up, in both nodes:
*> sysconfig -v
slot 0: 25G Ethernet Controller CX5
e0c MAC Address: XX:XX:XX:XX:XX:XX (auto-25g_cr-fd-up)
SFP Vendor: Amphenol
SFP Part Number: NDCCGF-N103
SFP Serial Number: XXXXXXXXXXXXXX
e0d MAC Address: XX:XX:XX:XX:XX:XX (auto-25g_cr-fd-up)
- Storage failover disabled in both nodes:
[node_name: statd: cf.takeover.disabled:alert]: HA mode, but takeover of partner is disabled due to reason : HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support.
