Storage show fault reports "ENCLOSURE BYPASSED"
Applies to
- ONTAP 9
Issue
ENCLOSURE BYPASSED
can be found instorage show fault
> storage show fault -v
Enclosure Status: non-critical
Channel: 3c
Shelf: 1
Shelf Type: DS4246
Product Serial Number: XXXXXXXXXXXX
Module Type: IOM6
Disk Elements:
Element Status Status Bytes Status Descriptions
19 [Bay 19]: OK 01,13,00,00
20 [Bay 20]: NONCRITICAL 03,14,10,04 ENCLOSURE BYPASSED B, BYPASSED B
21 [Bay 21]: OK 01,15,00,00
sysconfig -a
shows the effected disk is normal.
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
Firmware rev: 01.11.00.00
Base WWN: 5:00a098:0014dc6:88
Phy State: [0] Enabled, 6.0 Gb/s
[1] Enabled, 6.0 Gb/s
[2] Enabled, 6.0 Gb/s
[3] Enabled, 6.0 Gb/s
QSFP Vendor: Molex Inc.
QSFP Part Number: 112-00176+A0
QSFP Type: Passive Copper 0.5m ID:00
QSFP Serial Number: 235621256
01.19: NETAPP X308_SMNRY03TSSA NA00 2538.5GB 512B/sect (Z297CDM7)
01.20: NETAPP X308_THARR03TSSM NA00 2538.5GB 512B/sect (16S3K7ZUF)
01.21: NETAPP X308_THARR03TSSM NA00 2538.5GB 512B/sect (16SDK6P1F)
