NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
UCS SAN Boot Reference Documentation
826
Visibility:
Votes:
1
Category:
flexpod-with-infrastructure-automation
Specialty:
san
Last Updated:
Applies to
  •  SAN
  •  SAN Protocol
Connectivity related issues with Cisco UCS products can often be resolved by validating the configuration against the initial setup documentation. Below you will find documents for configuring Cisco UCS with NetApp storage. While most of the documentation is targeted at the Cisco/NetApp partnership program called Flexpod, it is important to note that these documents follow best practices put in place by both NetApp and Cisco.
If you are unable to find a guide that matches the your current configuration, there are additional guides available at  Cisco Flexpod Validated Designs as well as NetApp Validated Designs.
Scan to view the article on your device
