NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
How to match LUNs NAA number to its serial number
11,746
Visibility:
Votes:
8
Category:
flexpod-with-infrastructure-automation
Specialty:
virt
Last Updated:
Applies to
  • SAN
  • FlexPod
A LUN Network Address Authority (NAA) number is a globally unique identifier for a LUN. The NAA number can be used to determine a LUN's serial number and vice versa.
Procedure
Data ONTAP operating in 7-Mode or clustered Data ONTAP 8.3 or later include a LUN command to obtain the LUN serial number in the hexadecimal format:
lun serial -x /vol/test/lun
Serial (hex)#: 0x486e542d4f5a2f47694d684b
Take the example of a LUN with the following NAA number:
naa.60a98000486e542d4f5a2f47694d684b
Remove the NAA string and the first 8 characters. In this example, naa.60a98000 (this is one of the NetApp vendor identifiers).
The remaining value (486e542d4f5a2f47694d684b) is the hexadecimal string which, when converted from HEX to ASCII, will be the LUN serial number. There are many Web-based tools to convert HEX to ASCII and vice versa if you are using a version of Data ONTAP that does not have the lun serial -x command available.
486e542d4f5a2f47694d684b in HEX converts to an ASCII value of HnT-OZ/GiMhK
You can either use the output of the command lun show –v, or review the 'LUN CONFIGURATION' section of a storage system’s autosupport output to determine which is the LUN, based on the LUN serial number in the ASCII format.
The following is an example of the output of the lun show –v command:
Filer1> lun show -v /vol/test/lun
/vol/test/lun  5g (5368709120)(r/w, online, mapped)
Serial#: HnT-OZ/GiMhK
Share: none
Space Reservation: disabled
Multiprotocol Type: vmware
Maps: test=0
Note the LUN serial number above (HnT-0Z/GiMhK). The LUN with naa.60a98000486e542d4f5a2f47694d684b is /vol/test/lun.
Note: For more information on identifying disks in a VMware ESX environment, see VMware article 1014953.
NetApp NAA prefixes are as follows:
Clustered Data ONTAP and Data ONTAP 7-Mode naa.60a98000
Clustered Data ONTAP naa.600a0980
E-Series naa.60080e50
New to NetApp?
Scan to view the article on your device
