Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
NetApp Knowledge Base
Upgrading Nexus 3132 cluster network switch causes it to drop into switch boot prompt
666
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • Cisco Nexus 3000 series switches
Issue
  • When upgrading a Nexus 3000 series with compact or full image to release 7.0(3)I7(7) or 7.0(3)I7(8), it will reload and comes up in switch boot prompt.
  • Following error is seen:
Trim files after extracting TOR files ...
error while upgrading the firmware
/mnt/cfg/1 dir return 32 <<<<<<<<<<<<<<<<<<<<<
Config partitions are not partitioned properly.\nDisk will be re-initialized. <<<<<<<<<<<<<<<<<<<<<
switch(boot)#
prompt is then shown
New to NetApp?
Scan to view the article on your device
