NetApp Knowledge Base
UnsupportedSwitch_Alert reported for storage network switch
348
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF
  • Cluster Switch Health Monitoring (CSHM)
Issue
  • The following alerts are reported in the event logs for a two-node switchless cluster:
[Node-1: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: SwitchCommunityString_Alert[cluster-stor-sw2(XXXXXXXXXX)].
[Node-1: cshmd: hm.alert.raised:alert]: Alert Id = UnsupportedSwitch_Alert , Alerting Resource = cluster-stor-sw2(XXXXXXXXXX) raised by monitor ethernet-switch
  • The system health alert show command output shows the following information:
                      Node: Node-1
                   Monitor: ethernet-switch
                  Alert ID: SwitchCommunityString_Alert
         Alerting Resource: cluster-stor-sw2(XXXXXXXXXX)
                 Subsystem: Switch-Health
           Indication Time: Fri Nov 04 07:07:04 2022
        Perceived Severity: Major
            Probable Cause: Configuration_error
               Description: Ethernet switch "cluster-stor-sw2(XXXXXXXXXX)" with IP address "10.X.XXX.XXX" is not reachable via SNMP. Incorrect SNMP community string might be configured on the Ethernet switch.
        Corrective Actions: Check the SNMP community string on the Ethernet switch to verify that the expected community string is configured. Use the "system switch ethernet show -snmp-config" command to view the expected community string.
           Possible Effect: Ethernet switch communication problems and accessibility issues.
                      Node: Node-1
                  Alert ID: UnsupportedSwitch_Alert
               Description: Unsupported Ethernet switch is detected.
        Corrective Actions: Unsupported Ethernet switch "cluster-stor-sw2(XXXXXXXXXX)" found. Connect a supported Ethernet switch to the network.
           Possible Effect: Communication problems and network connectivity issues occur.
  • The switch health is degraded due to these alerts:
Cluster::> system health subsystem show
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     degraded
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster ok
New to NetApp?
